Hi all, could use some help. New poster.
I live in a small flat on the 2nd floor. I first noticed a problem when I smelt dirty water coming from the bathroom sink. I wasn't sure what it was, but a few days later the washing machine outlet pipe backed up and caused some flooding to the kitchen floor.
I did the normal layman tricks of trying Mr Muscle and the old wives tale of white vinegar with baking soda but it didn't achieve much.
Afterwards, the kitchen sink started to drain slowly.
To give an insight into the system, the further drainage is the kitchen sink, which links to the washing machine discharge pipe. This all goes into the same pipe through the wall to the bathroom sink discharge. This is on the opposite side of the wall so we are talking a few inches between the two.
The bathroom sink then links down the side of the bath panels into the bath plughole. This then goes to the drainage which is boxed in behind the toilet and presumably close to the soil stack for the toilet.
My problem is that the bathroom sink is boxed in so I will need to have a plumber take a look at this and do some sawing into it.
Inevitably I will need a plumber to look at this. I wanted to check a couple of things with you guys before I give him a call so I don't look like an idiot. I have attached some labelled photos to help you out.
(1) Does the plastic pipework under my sink look ok? There seems to be an extra and potentially unnecessary bend. Your thoughts would be appreciated. I am not against having the pipework changed.
(2) I presume I have a blockage somewhere in the system. I am guessing it is the bathroom sink How much do you think it would cost to have a guy in Bristol to take a look at the system and work his magic?
Many thanks.
Many thanks.
