Slow drip in water tank ballcock valve
31 Aug 2015
Ireland
Hello,
There is a slow drip in the attick water tank. To explain in detail, after use, e.g. flushing the toilet the tank refills quickly. Then the rate slows to a trickle and then an ever slowing drip (maybe 1 drip every 10 - 20 seconds). The thing is this drip could last all night, 12+ hours without any water being used in the house. It doesnt seem to ever shut off. If I depress the ballcock to add extra water into the tank it will then shut off.
The tank is the black plastic kind.
Do I need to change the ballcock and valve?
Regards,
Michael
If the noise is driving you mad - tie a piece of string for the water to run down - temporary job but it won't drip
2 great suggestions. Thanks. I wouldnt be half as bothered if it wasnt for the noise.
Ill tie the string and change the valve/ballcock.
If you don't like tinkering, just fit a new valve. The Pegler Prestex Part 2 is probably the best you can get.
http://www.screwfix.com/p/pegler-prestex-float-valve-part-2/27627
You can buy an inferior valve if you feel you need more practice changing and repairing them. Read both pages of reviews.
If you do like tinkering, fit a new valve, then take the old one apart on the kitchen table at your leisure, clean it up, fit a new cone and washer, and put it next to the tank, in a plastic bag, ready to swap back in 10 or 20 years when it needs doing again.
I replaced the washer. Verdict is out on wether the drip has stopped yet. I havent had time to check a few hours after use.
However now when the water flows through the valve it vibrates/shudders really loud. What is wrong?
From the replies it seemed like the easier option was a washer change.
Now I will change the valve and put a metal plate on the outside of the plastic tank (which is currently missing).
Is that a job I can do easily? Is the metal plate easy to install?
Always easier to just replace the complete valve. I use Fluidmaster Pro75B valves
Good recommendation.
I get fed up with noisy float valves;
Recently tried this one; but just a bit too noisy, creaky, groany and takes too long to turn off completely,....but that’s just how they are.
Also this one; ditto.
So I tried this one;.....very quiet, quick fill and shuts off instantly with barely a whisper,...... “Silent Night”....excellent.
There is nothing intrinsically wrong with the ‘traditional’ float valves but if you want a fill that’s as quiet and quick as possible the ‘Fluidmaster’ is very good.
