Slow flow on new bath taps?
If the kitchen cold tap is slow, the problem won't be anything to do with the boiler. Either the baxi engineer is telling porkies about the flow rate, or something has changed.
Do you know what your water pressure is?
Does the manufacturer state a minimum pressure for your new taps?
Sorry for the delay in getting back i've been away a few days. The problem is resolved. The taps were not the twin ones with built in shower hose. The problem was the boiler. I got Baxi out as i was certain it wasn't the taps or something i'd done, and i have warranty so why not use it.
He checked my filters which were clean, removed the heat exchanger which he said would more than likely be ok as when they go the boiler tends to get very hot. in the end it was a little valve under the hall sensor which is on the hydraulic valve assembly. It looked clean from the outside but he changed it anyway and i got my 5 litres per minute extra back.
It was this and not the other parts we checked as we fired the boiler up after every component check.
