    Dismiss Notice
Slow flush from cistern - new toilet
Discussion in 'Plumbing and Central Heating' started by Deisler, 1 Sep 2020.
  1. Deisler
    Deisler
    15 May 2017
    7
    Thanks Received:
    2
    Country:
    Good evening,
    I just installed a new back-to-wall toilet unit with new concealed cistern. Everything works fine, apart from the flush from the cistern into the bowl is slow.
    The flush from the bowl into the waste/soil pipe looks normal. The fill value works ok too.
    I do not understand how the flush from the cistern can be slow on a new toilet unit. There is very little water coming out of the holes at the front side of the bowl. I checked the holes - they are not blocked.
    Any idea why this happens?
    * When I fit the flush pipe (the one connects the cistern to the bowl), I remember I cut the length of the pipe so that it goes right to the end of the hole when I push the toilet back to the unit. Do you think this would cause the issue?
    Cheers,
    Jamie
  2. Sponsored Links
  3. Chris_W
    Chris_W
    26 Sep 2019
    3,626
    Thanks Received:
    958
    North
    Country:
    Not usually, it’s usually a restriction of some sort. Have you checked the flush pipe, and the holes where it connects to?
    • Thanks Thanks x 1
  4. Deisler
    Deisler
    15 May 2017
    7
    Thanks Received:
    2
    Country:
    The flush pipe is new. I did not check the holes it connects to (because everything is new...).
    The problem is I have already silicone-sealed the toilet with the unit. So before I cut the silicone and make a mess, I want to know exactly what I should check.
    I forgot to add that the water level in the tank is also correct - filling only 20mm below the overflow pipe.
  5. lostinthelight
    lostinthelight
    11 Feb 2016
    2,233
    Thanks Received:
    406
    monmouthshire
    Country:
    Some cones have a stop around the circumference to stop the flush tube going in all the way
    • Like Like x 1
  6. Chris_W
    Chris_W
    26 Sep 2019
    3,626
    Thanks Received:
    958
    North
    Country:
    I’ve had loads of “new” installs, only to find their flush isn’t strong, take apart and voila, tile spacers clogging up the new flush pipe :whistle:
  7. Deisler
    Deisler
    15 May 2017
    7
    Thanks Received:
    2
    Country:
    I kinda hope mine does not have that, so it will be an easy fix, i.e. cutting the flush pipe, although I need to cut all the silicone off first.... grrr
  8. Deisler
    Deisler
    15 May 2017
    7
    Thanks Received:
    2
    Country:
    Just to leave a note here that it was indeed caused by the flush pipe being inserted too tight. Cut the pipe by 10mm and problem solved.....
    • Thanks Thanks x 2
    • Like Like x 1
  9. Sponsored Links
Loading...
Share This Page
