Hi there,
i'm hoping someone can help with some advice on the following.
I have a Worcester Bosch 28i-s combi boiler, The hot water has reduced in recent weeks to not much more than a trickle. Although it does improve a bit when the central heating is turned on? (We are in a very hard water area)
Do you think it could be the hot water heat exchanger that is blocked with scale and if so is it easy / difficult to remove and either flush and clean it or replace with a new one?
Or does the fact that the hot water flow improves when the heating is turned on mean that there are other gremlins at work in the boiler ?
Any help / advice greatly appreciated.
thanks
Pete
thanks
Pete
