I've just had a new central heating system installed and the recovery/heat up time for the water is very very slow.
My old system was a vented one and when the water was boosted the boiler would throttle up and run at maximum for a period of time (maybe 10 mins depending on the initial temp of the water in the tank) before gradually throttling/modulating down to its minimum as the tank heated up. With the new system when the hot water is boosted the boiler starts up but never really gets beyond its minimum setting.
The tank is an unvented Gledhill 300lt solar, the boiler is Worcester Bosch Greenstar 15Ri and all the pipework is new.
The boiler is heating a larger volume of water (175lt) than before so perhaps it should take longer but I don't understand why the boiler never gets about its minimum setting. From 20deg it takes 90mins plus to reach 55deg vs the published heatup time of 40mins to 60 deg. With my boiler I would never achieve the published heat up time but something doesn't seem quite right.
Any ideas welcomed!
Norm
PS The heating side of things works fine so its not the boiler. I hope . . .
Any ideas welcomed!
Norm
