- Joined
- 19 Feb 2019
- Messages
- 5
- Reaction score
- 0
- Country
Hi
I'm wondering if anyone can recommend an under-sink drainage pump which would help drain a utility sink on a long horizontal run, in the UK?
Background:
I have a problem with the sink in our utility room draining slowly. Because of this, when the connected washing machine pumps out waste water, it fills the sink first before draining away.
I've checked for blockages in the pipework above the floor, but it seems the issue is below. It's been rodded and had drain-cleaning acid put down without much effect. I don't have good access the waste pipes, but I can see it's a fairly long run - around 10m including a right-angled bend. There's very little fall on the waste pipe from what I can tell.
Ideally the entire pipe run would be replaced with a larger diameter, and a decent fall but since I can't do that, I'm wondering if the solution would be to get some sort of pump. They seem fairly common in the US for basement laundry but not so much in the UK. Price is obviously important too. I doubt it needs to be very powerful.
Background:
