In a house, is it usual for sludge just to build up in the downstairs pipes and radiators (boiler, pump and valves downstairs, cylinder upstairs) or will it be evenly distributed?
I was quite amazed, given it's the highest point, by how much sludge was in the F+E tank in my house when I moved in. I've since cleaned the tank, flushed the system, run with cleaning stuff etc - it made the system much quieter!
I suspect that more sludge will accumulate at the bottom of pipework / rads etc, but if you've got a good pump going then there will be a fair bit of circulation, so the 'looser' sludge will flow round, and I guess just get dumped whever it is when the pump stops (and potentially solidify / attach etc at those points)...
Yes, I'm trying to fix my elderly uncle's heating (fitted in 1970), I've spent 3 days on it, every time I do one thing, there's a different problem with something else, the whole system is definately possessed! The downstairs rads are sludged up, so, I was hoping the upstairs wouldn't be if it always settles at the lowest points.
