I have recently taken on a three storey house with gas central heating system. There are two rads in the kitchen which is on the ground floor. These rads are sluggish and no-one seems to know what the problem is! The symptoms are;
Take much longer to heat than the others in the property
One valve is scorching hot, whereas the other is only just warm - almost cold, regardless of the temp of the rad
The rads heat from the top down but the bottom never really gets as hot as the rest
They don't need bleeding as they are hot at the top. The system has recently been balanced and the boiler has had a new pump. They do eventually get hot but I'm talking an hour (maybe longer) after the heatings been cranked up.
Please bear in mind I have very little knowledge about plumbing or DIY in general, but any advice would be greatly received. I'm new to this whole DIY world but eager to learn
Also, can anyone advice whether my sluggish rads will be having a negative effect on the rest of the system?
