Hi folks,
I'm about to wire in my 14.4Kw SMEG A1-5 cooker. It comes with 13AMP plug. Clearly the cooker needs more than a 13AMP circuit. So I am installing a 45AMP switch and running 10mm2 cable to/from the consumer unit with a 30AMP MCB. My question is why does the vendor supply a 13AMP plug when the power it consumes is going to above 13AMP. Also the cable to the cooker from the cooker connection unit is much smaller than the cable I'm gonna lay to/from the consumer unit.
Am I missing something or is this how cooker are?
Cheers,
Tas
Cheers,
Tas
