Socket bits, triple square, double hex and spline
4 Dec 2013
Powys
Ok so i have a strange bolt i need to remove, and after a bit of looking around on the internet i think it requires either a triple square, double hex or spline socket bit to do so. My question is, these all look the same to me is there a difference between the three or is it just a case of different manufacturers giving them different names? How can i tell which one i need if they are all different?
Thankls in advance
Mole grips! :D :D
Seriously though, a photo would help people in identifying it.
I have often wondered what the difference is between Phillips and PoziDrive - if indeed there is any....
Posidrive have an extra 4 contact points between the main blades.
Thanks for all the responses i have now sorted the problem after borrowing a friends socket bit set.
They are also a different profile.
Guaranteed way to damage a tight Phillips screw is to use a Posidrive bit. Likewise a tight posidrive screw will be damaged by using a Phillips bit.
