Socket for my loft
24 Jan 2007
West Midlands
Hi All
I want to put a power socket in my loft. Unfortunately the socket ring main goes nowhere near the loft. However, there is a fused spur going to the house alarm 'brain' in the airing cupboard.
My question is this. Can I take an additional spur off this fused spur without affecting the operation of the house alarm?
Thanks in advance for everyone's help.
Regards
Dave
Yes but both the alarm and the new socket must BOTH run through a "master" fused spur to prevent the combined load drawing more than 13 amps.
Withdrawing power to the house alarm should not cause problems if the battery is well maintained (changed 5 yearly)
You may find that the alarm is on its own 16A breaker. If so, then you can just wire your new cable into the FEED side of the alarm fcu and not worry about a 'master' fcu. You don't need to limit a 2.5mm cable to 13A.
Thanks for your replies sofar..
I have checked the fuse inside the spur and it is 5A. Will I have to insert a higher rated fuse as there will be a socket connected to it? I only intend to use the socket for lights/DIY tools/radio..
Thanks in advance again.
Dave
Don't worry about the fuse in the fcu. And definitely don't change it for a 13A. Look at your main fuse or breaker for the alarm circuit and find out what rating it is. They are often B16. This would do fine, as long as you connect your socket circuit to the FEED side of the fcu.
You will need RCD protection for the new socket. If the alarm circuit is not already protected, use an RCD socket.
If it IS already RCD protected by means of an RCBO, then you don't really want to start putting additional portable loads on the same circuit.
