- Joined
- 15 Nov 2019
- Messages
- 37
- Reaction score
- 2
- Country
I was wondering too about a potentially hidden FCU, because I don’t remember the original electrician telling me he had installed one, plus the inaccessible space I mentioned is behind a panel that has always been there. I can’t remember the electrician tinkering behind that panel either, and it seems a strange place to install a consumer unit. So, maybe there isn’t one.If it hsa been protected by an FCU it should have been installed in an easily accessible place and pointed out to you what it was for. So unless it has been covered by some later instalation it would seem unlikely you have one. My guess would be on a loose connection in the back of the socket itself which you could check yourself as I described in previous post. No there should be no urgency if the socket is unused
If there is a loose connection behind the socket though, it is affecting both sides of the double socket. I will look again, but when I unscrewed the socket from its box, I didn’t notice anything clearly visible. If there is nothing obvious, I am still going to eventually need to call another electrician.
