Sockets switch tripping although no sockets switched on.
21 Apr 2011
Yorkshire
My main sockets keep tripping, well in fact they have tripped and now the switch just trips instantly the moment I reset it. I have switched all sockets of and yet it still won't reset, I had a complete rewire done about 18 months ago so don't understand what is happening, any help.
You have a fault on your fixed wiring. This could be damp from a leak or mechanical damage from a rodent or recent DIY ?
So I guess the only way to get it sorted is get an electrician out.what does the repair involve? Thanks
Try unplugging everything, rather than just switching off, it could be a faulty appliance. Dont forget about any sockets that may me hidden, eg. fridge, dishwasher or boiler ect.
Something in your house. Lots to choose from.
Do you have any outside sockets/wiring?
Have you checked things like central heating pumps & valves?
Have you turned off averything and unplugged everything?
Once you have run over those then you'll need an electrcian who is competent in fault finding.
Oh, one last thing, you say
What is this switch? is it in the consumer unit? Is it an MCB or an RCD or an RCBO?
what is written on it. ?
Physically disconnect everything from the circuit, IE : Unplug all the appliances. Next find any fused spurs that are running off the circuit and remove the fuses, or switch them off. If you had a recent rewire your distribution board should be marked up, so you can tell which circuit is effected, I am guessing it will be either kitchen, upstairs, or downstairs rings. If you do all of the above and the MCB still won't hold in, you need to call in the electrician who did the rewire, or another competant person.
If you do the above and your ring holds in you have to isolate which item is causing the problem, plug them in one at a time until it trips out, that is the faulty item.
It may be that your recent rewire has replaced your fuseboard with one that includes an RCD, (Residual Current Device) if this is the case the above is still true, but the whole board, or only the none lighting part of the board will trip out.
You need to disconnect / unplug everything as above, see if the RCD will then hold in, and re-connect / plug in everything one at a time until you find the item causing the problem.
CW.
