Soffit vent covering?
2 Mar 2003
Yorkshire
Our house has these vents cut into the wooden soffits, which look ugly. (Admittedly they need tidying up a bit)
Am I ok in covering these soffits with uPVC cladding or do they need full and complete access to air flow?
Appreciate your advice
Cold roof - ouch!
Each joist run needs to be vented to the outside, with flow at each end. It’s why you rarely see cold roofs these days. Mind you, the deep warm roofs are not much better.
That what you are seeing is ‘fascia’ not soffit. Your roof has zero soffit (no overhang). If it did, it would enable you to vent more discreetly.
How does it vent the other end, as it is a kitchen extension butting up to the main body of the house?
See if you can either cut some of that fascia or remove it before fitting the plastic fascia and fit a strip vent at the bottom instead
Pull one out and see if you have any insulation would be my advice before you proceed.
