Yet more soil pipe questions!
It seems my original plan won't work as the pipe exit through my outside wall is only 7 inches from the soil stack (centre to centre) and I an not find any means of making the connection.
The guy at the plumb store suggesting running along the inside wall a bit and then doubling back and coming in from the other side of the stack. He said as long as the fall is there it wont be an issue.
So there would be a 90 degree right hand coupling from the pan to 1.4M of pipe. Then a 90 deg right hand bend followed by 0.5M pipe to another 90 deg bend this time left hand through the wall of the house this will be about 300mm to another 90 degree left hand bend (so this section make a U turn through the wall) then straight run of about 400mm into the stack. From the pan exit to the point the pipe crosses the wall is about 75-100mm drop this distances is about 2M.
Really appreciate any advice on this as it's driving me mad!
