Soil pipe & pan connector sizes
19 Feb 2009
While replacing my toilet I noticed the soil pipe wasn't the standard 110mm but is the smaller size 82mm?
I went to the merchant and told him I wanted a pan connector for this situation, when I got home and offered it up it was smaller even that the 82mm. It said 3 inch on the packet!, is it possible to get a 82mm pan connector?
How many sizes of soil pipes are there, this 3 inch one looks like a drainpipe size, surely they would just block??
I'm confused :?
You have a 3" soil pipe branch?
Do you have a 3" soil stack too?
When was the soil system installed like that, why, how, where, and who by?
Oh, and what the blazes?!
Hi Goldberg
The soil stack and branch measure about 3 1/2 inch, the merchant gave me the wrong connector, this one looks soooooo narrow inside (bottleneck).
Is there such thing as 3 ich soil?
I was being lazy. For 3" please read 82mm, or whatever yours is.
The Building Regulations require you to have an "adequate system of drainage", without specifying pipe sizes. However, since BS EN 12056-2:2000 specifies pipe sizes and is used as a reference by soil pipe manufacturers, it is a de-facto standard. The upshot is that you'd be crazy to use anything smaller than 110mm pipe for the outlet from a WC, and for the continuing foul waste system.
How much of your soil pipework is smaller than 110mm?
My neighbour has 110mm plastic, mine is all 3 1/2 inch (82mm?)
I don't think 82mm pipe is intended for anything other than venting - has someone plumbed your WC into a vent pipe?
The designation of 110mm soil pipe is the inside diameter so the OD is more like 116mm.
If you're measuring 82mm as the OD, which BTW is less than 3 1/4", then the ID will be more like 76mm. The CSA of this is less than half that of 110mm pipe. :shock:
If you buy a pan connector to fit inside your pipe, then the ID of the pan connector will be so small that you could never invite John Prescott round for a heavy dinner.
Setting aside my apparent naivety at an installation like yours being possible, what scope do you have for fitting a Fernco coupling and a short section of 110mm pipe, into which you can put a standard pan connector?
3 1/2" McAlpine pan connector, job done
kirkie ye got a picture?
WC-CON2B
Straight Reducer Adjustable Length 90 - 118mm Pan Spigot to 3½ inch/ 90mm
Google Multikwik
MKS3 Standard Straight WC Connector
Pan Spigot = 108mm - 114mm
Pipe Size = 88mm - 92mm
cant get a photo either!!
