i am building an extension that goes over an existing manhole.
i want to replace the section of pipe in the manhole, and make use of the other 2 manholes situated on the same line either side within 3 mtrs.
the manole i want to replace the pipe only houses the stack waste from my own property and no others.
can i put a swept t in when replacing the section of pipe and connect my waste to it, bearing in mind that the other manholes are close and on the same line, or do i need to have access to rod the 1mtr peice of pipe going from my property into the swept T
i did think about connecting it to one of the other manholes, but this will involve a 90oc bend terminating into the manhole and i am not sure it is allowed.
HELP
HELP
