Solar battery
It seems you were getting around 7p/kWh for export, which is not as good as the 12p/kWh I get now, but go back a year and it was 15p/kWh, but it seems when SEG first replaced FIT the export rate was rather bad.
April I was paying 6.5p/kWh for off-peak, peak 29.702p/kWh today off-peak 9.4p/kWh, peak 35.75p/kWh which means we don't really know what the return will be, it varies so much in such a short time.
Standing charge 69.026p/day to 66.74p/day. So that has not varied as much.
So I have 14 panels, but that says very little, they are rated at 6 kW which I would not see, as inverter only 5 kW, but I have not seen the graph flat line very much, so it would seem it is rare to even get 5 kW from them.
Looking over the year, seems I have never exported more than 28 kWh. 616.7 kWh for July 2026. So with South/West facing panels average even on best mouth did not exceed 20 kWh per day.
Looking at worst month, just below 18 kWh per month exported and imported 400 kWh.
But all that is not really important, what is important is how much we use per day, if this exceeds the battery size, we can run on just off-peak, but there are a few problems.
1) Use varies day to day.
2) The amount of solar varies day to day.
3) The batteries have a limited life.
So if we look at battery life of 12 years, going silly and having say 25 kWh of batteries when your using 12 kWh per day on average, is unlikely to pay for its self.
I have no clue about all this but 5-8k is a lot of money. Although it not just about saving money, its having that resiliency if we lost the grid.
Realistically, (and yes, I know it's likely to get worse), how often and for how long do you lose grid power?
Solar systems with batteries have their place, but the ROI period is long, and whatever financial calculations you do are entirely at the whim of the supplier(s) - they could change their tariffs at any time and completely change the investment case.
Their place is not resilience against temporary power cuts. Of course they are very good at providing such resilience, but to invest in such a system purely for resilience makes no sense - that's what portable generators are for.
If you have an EV anyway, adding V2G could be worthwhile.
1795342193176.pngThis are what I am getting in case of a power cut. What I want is to avoid being plunged into total darkness, within the time it takes for the batteries to deplete, I can take other measures, but light is the important thing.
One of these
sorts out cooking, which leaves the freezers. The chest freezer likely good for at least 8 hours, the upright freezer is more of a problem, if one is unlucky enough to loose power while it is on the de-frost cycle then you may only have ½ hour for items on upper shelves, but the de-frost cycle is around once every 36 hours on mine, so you would need to be very unlucky. So as long as door not opened then around the same as chest freezer.
So in the main, the one item which we want reasonable back-up for is the heating, this was my problem in the 1978 Winter of Discontent my hot air central heating with single glazed picture windows allowed the house to cool too quickly, and we had no alternative heating which did not need 230 volt electric to run.
Next house had a gas fire, and this house has an open grate, not that I want to use the latter, but I do have a way to heat the home.
So 1795343398903.pngor
seem to be the easy way, as to getting enough gas once we get power cuts is another thing, and to have a back-up to run the central heating does seem a good move.
But to have a battery system which has a EPS function is expensive, we are jumping from a couple of hundred to thousands of pounds to have the central heating battery backed.
Also a conflict of interest, to insure it does have power for the central heating, it needs to be set not to fully discharge, so although I have 6.4 kWh, if the power cut happens at the wrong time, I may only have 640 watt hours (mine set to reserve 10%) well not even that, as some held back to work the inverter, so likely more like 400 watt hours.
So this 1795344130916.pngwould work just as well.
So in real terms, solar, battery, and off-peak work as a package, and unless you have all of the system working together, any one does not really pay for its self. Even with them all, we are looking at 6 to 10 years pay back time, and at the whim of suppliers and government as to how tariffs will change.
Through the years we have seen it many times, the storage heater must be the classic. The Economy 7 was to start with giving off-peak at around a 20% of standard price, and you still had the standard price to fall back on, then the raised the peak price if you had off-peak, and then slowly increased the price of off-peak, even this year, don't need to look too far back, off-peak was 6.5p/kWh in April, now 9.4p/kWh the price caps do not really work with a split tariff, so 35.75p/kWh peak.
I was considering a third battery, but the rules have changed, so no longer can a third be put with the other two, it will require an out building to house the battery. So what I thought was a simple up-grade, no longer is simple.
Basically, only those who have loads of disposable income can afford a battery/solar system, our gains have just taken a large hit, we find to repair last years snow damage when the snow slid of the solar panels in a rush, and took the gutters down, is going to cost £4k to put right. OK it may have failed this year or next year even without solar panels, but the way snow slides off solar panels clearly made them fall off prematurely.
But is seems today batteries need to be 1 meter or more from the main building, and limited in the main to 20 kWh maximum so this rules out having a heat pump.
