- Joined
- 27 Jan 2008
- Messages
- 29,928
- Reaction score
- 3,729
- Location
- Llanfair Caereinion, Nr Welshpool
- Country
It seems you were getting around 7p/kWh for export, which is not as good as the 12p/kWh I get now, but go back a year and it was 15p/kWh, but it seems when SEG first replaced FIT the export rate was rather bad.
April I was paying 6.5p/kWh for off-peak, peak 29.702p/kWh today off-peak 9.4p/kWh, peak 35.75p/kWh which means we don't really know what the return will be, it varies so much in such a short time.
Standing charge 69.026p/day to 66.74p/day. So that has not varied as much.
So I have 14 panels, but that says very little, they are rated at 6 kW which I would not see, as inverter only 5 kW, but I have not seen the graph flat line very much, so it would seem it is rare to even get 5 kW from them.
Looking over the year, seems I have never exported more than 28 kWh. 616.7 kWh for July 2026. So with South/West facing panels average even on best mouth did not exceed 20 kWh per day.
Looking at worst month, just below 18 kWh per month exported and imported 400 kWh.
But all that is not really important, what is important is how much we use per day, if this exceeds the battery size, we can run on just off-peak, but there are a few problems.
1) Use varies day to day.
2) The amount of solar varies day to day.
3) The batteries have a limited life.
So if we look at battery life of 12 years, going silly and having say 25 kWh of batteries when your using 12 kWh per day on average, is unlikely to pay for its self.
