solderd fitting looks cracked?
6 Feb 2010
Blackpool
Even though the solder looked to run well around this elbow when I applied the heat and solder. On the front lip it looks like its not filled in one place?
Nope, work the heat from the pipe end of the fitting up to the joint, just work quickly with that one area.
Chances are it's run ok tho and if you could test just now that'll tell you.
Thanks even with the gap between the pipe and the fitting lip? Is it likely the solder has run all the way around further down the fitting
Yup, if you followed the golden rule, arnd 15mm solder for 15mm pipe, 22mm for 22mm etc .... then it should be fine, but again, it's all in correct testing and commissioning.
A touch of heat and solder dipped in flux will sort it if you're not happy. You will get a feel for it as you build more confidence.(y)
lol, you're just not convinced are you?? ;)
Have I come across soldering that looks like your's and worse on old pipework and has been leak free for years, yup, loads of times. Mine are perfect you see ;) Have a I had to fill a little gap that was left when I've soldered then, yes, usually when it's still hot tho. That being said I would still have confidence in my soldering to re-warm a new joint and make it good. It's an experience thing TBH, I guess you're new to soldering?
Ultimately if you're at all unhappy then in the time it took to get the 1st reply to this, it could have been re-made. :whistle::)
