Solid Doors.. for internal wardrobe
13 Feb 2006
Tyne and Wear
We have a walk in wardrobe, which has an opening size of about 1100mm.
A joiner cut down and fitted two normal internal doors a while ago, but the hinges have come loose. I think this is because there is too little wood on the hinge side to screw the hinges too (screwed end-on to the door edge)
I think the best idea would be to buy two solid doors, then fit these.
I assume this is how fire doors are made, but they are expensive and pretty heavy. furthermore, they are thicker than the existing internal doors, which would involve some frame re-design. A lot of faff I think.
Is there another option please ?
The gap is too small for sliding doors.
thanks for any input
Whats a normal internal door? hundreds of varieties. Couple of pine panel doors are lightweight.Firedoors are dense not solid.
