WTF do you know about itplumberman_uk said:instead of insulting each other how about getting back to the
topic?![]()
d1ynut said:(after 25 years completely trouble free)
(heating itself normal - DHW is cold)
anyone advise on likely cause/recommendations please?
Softus said:1. Lack of water in F&E?
d1ynut said:...
wife had dumped stuff in the loft that was constricting water supply - i had complained about access and *had* asked her to check water level !!!
Softus said:Hi d1ynut - could you recap - what did the fault turn out to be?
d1ynut said:the hot water is generated by gravity
the little "open" plastic feed tank in the loft had run dry
Is there something else you feel needs to be said?plumberman_uk said:instead of insulting each other how about getting back to the topic?![]()
Bamber gaspipe said:...an F&E tank has nothing to do with Hot water... it fills the Central heating system.
Bamber gaspipe said:I agree for once with you..from now on I will ignore..
Bamber gaspipe said:I know what has happened in this case
Agile said:Most likely fault after 25 years is the pump have failed.
You weren't ignored because you didn't explain any such thing.Agile said:Softus does not seem to have noticed that buried in the many posts some while ago the original poster has explained that the F&E tank had become dry just as I suggested but as usual I was ignored!
Quite so.Pearls and swine!
Firstly, whilst we may have a truce, which to me means that you may expect that I won't attack you and I, in turn, expect that you won't attack me, it doesn't mean that I've changed personality and/or lost my memory.Bamber gaspipe said:Because of your statement that the lack of Hot water was caused by low or no content in F&E tank...Define F&E you are a plumber..this is not meant to be antagonistic..what is an F&E tank.
.Previously you've stated that I'm not a plumber, and now you state that I am one
You were strident, arrogant even, in your first claim, and I see no reason for you to have changed your view.
Secondly, as I've stated before, on other topics that you might not have read, if I'm wrong then I will say that I'm wrong,
However, this is an extremely rare event - something that clearly annoys many people.
I've spent many decades observing people being annoyed at me for being right when they least expect it.
I suppose I should be flattered that you went to all that trouble, but I can't be sure that the act was well-intentioned, since your posts still have an undercurrent of wanting to undermine and wrongfoot me - a pointless goal since if it turns out that I'm wrong on this topic then I won't deny it.Bamber gaspipe said:.Previously you've stated that I'm not a plumber, and now you state that I am one
Only because I dug up one of your old posts declaring that you were a `General plumber`.
In which case, if you're the plumber and I'm not, I don't understand your reticence in explaining, for all to see, what you believe to be the cause of the fault with the original poster's hot water.I haven`t, like I said..I dug up one of your old posts...You were strident, arrogant even, in your first claim, and I see no reason for you to have changed your view.
No you won`t because you always think you`re right...as your next little gem shows quite clearly..I think..
My statements showed exactly the opposite of your claim that I think I'm always right - they showed that I know that I'm not always right.Softus said:However, this is an extremely rare event - something that clearly annoys many people.
Being wrong only rarely is a fact, not an expectation or opinion, and has nothing to do with modesty.Modesty is not one of your endearing qualities then..
It doesn't take much effort to read the questions, but here they are, for the third time of asking:I can`t really be a***d going through the rest.. was there a point...?
