Hi, all bit new to this forum but here goes see if anyone can help, i have had fitted a new high output multifuel boiler stove burns mostly wood, connects to indirect cylinder in the attic and separate radiator circuit. System ran fine for week or two then after running a bath the other night the hot tap eventually runs out of water - this always happened with the old set up with the baxi boiler. So on firing up the stove today after being cold for a day it heated up quickly and then the banging noises started, bit frightening! After running the hot tap in the bath a lot of air came out and then the system has settled down ok, anyone got any ideas why this may have happened? And why my hot tap in the bath gives hot water for a while then seems to run out to a trickle causing some kind of airlock?? Thanks for any advice.
