I have just returned from my sisters cottage in Wales. My deceased brother-in-law had but down the above on to a concrete floor ( 25 years old ) with hard vinyl tiles on top.. The floor is about 4 sq meters, I have removed the skirting board on two sides he left no expansion gap and the floor is now buckling on one side only. I have removed one 12 cm board with difficulty using a jigsaw to check for damp ( all OK ) but the vinyl tile is stuck to the board with the adhesive.
My plan was to initially remove with a circular saw a 15 mm piece all around the floor to create an expansion gap but I can't find equipment that will enable me to cut this close to the wall.
All rotary saws only cut to a depth of 12mm as well.
Alternatively remove all loose boards about a meter wide with circular saw and re-lay leaving the expansion gap.
I am trying to preserve the integrity of the present floor as much as possible.
Any advice would be most appreciated.
Rob
Any ideas would be appreciated
Rob
