Solid Wood Floor Fixed to Joists?
3 Mar 2007
Cheshire
Hi
Currently renovating my house and I would like to fit a hard wood floor, Oak or similar throughout the ground floor. Current floor has boards on joists, suspended over dry concrete slab, approx 18” void. House is mid 60’s build.
I am considering removing the existing floor boards and fixing the new floor direct to the joists. I am assuming new boards will be at least as thick as the existing boards (19-22mm).
I would be grateful for your comments on this approach as it does not appear to be common. With regard to insulation would it be appropriate to use a foil backed sheet type under the boards.
Regards
Rob
rob - fixing a replacement floor directly to the joist is common practice; we always try to do it this way for a number of good reasons. By replacing the existing boards with matching thickness you can maintain floor levels/heights, you can often slip the new boards under the skirtings and door trims without removing them, But I think the most important reason is you'd be securly nailing into structural timber (directly into the joists); of course you'd have to secret nail with floor cleats - hire an air floor nailer & compressor.
Symptoms
Thanks for the reply, you have confirmed what I was thinking even if I had to batten to the joists to get centres down, it would be a proper job.
However time has become an issue, therefore I will need to progress with a 6mm ply and a 14mm board over the existing floorboards. You have highlighted my biggest concern about heights, but this approach should not end up too much higher than carpet and underlay and I am replacing the skirting and doors.
Also none of the installers I spoke to were very keen to take up and replace existing boards.
Regards
Rob
