Normally you only have to nail a solid wood flooring if you install it directly onto joist. Using a Portanailer or the likes with appropriate nails you wouldn't have to pre-drill holes (of course, as you've indicated, depending on the quality and thickness of the tongue. Some manufacturers advice nailing into the groove though. but I find that hard to imagine )Eddie M said:Also, going back to the original question, the nailing thing, doesn't that depend on the wood used, I've heard (remember I'm only a DIY'er) that say oak for instance is better, drilled and screwed due to the fact that invisible nailing, may well spilt the tongue, making the bond useless.
Albo99 said:The assistant in the DIY shop said that normal laminate PVA glue would be OK for hardwood which is water based. I'm not sure if this glue is strong enough for it??
