Solution to top up battery with no electricity in my garage
21 Feb 2011
Yorkshire
I have a Fiesta St Line 1.0 2021 and do very little mileage due to working from home.
With no electricity in my garage, I need a solution to topping the battery up.
Taking the car battery out isn't a viable solution.
Is there a large battery pack with inverter that will do the job or another solution please?
Solar charger on the roof of the garage if you want to keep it topped up or maybe just a booster pack for when you want to take it out and the battery is flat? Once started, it will charge up pretty quickly.
Can you recommend 1 or more solar chargers please?
Leisure battery + inverter is not only over-kill for your purpose but also pricier than a maintenance free solar panel.
Besides, with no lecky in the garage you would be back to square one .. how would you charge the leisure batt :unsure:
I have an AA one of these that works well under similar circumstances. You could mount it on a window ledge inside the garage but outside the car
Or extend the lead and mount it on the front/side/back of the garage.
Not sure the AA one would weather very well outside. Plus you might get too much volt drop if you had to extend the lead far.
