I have some wastes.to run. I am doing 110mm in pushfit. And the 32mm and 40mm in solvent. What is best to connect to a boss/ the boss eye of a 110mm branch. Are the rubber ada
I want to boss into to the eye of a 110mm branch. If I use solvent am I best of with a solvent boss adapter to 40mm or can you still use the rubber ones? Thanks
