Some Sort of Pressure Problem
3 Feb 2008
Kent
A friend of mine has a conventional gravity fed central heating system.
Potterton Kingfisher floor standing boiler, hot water cylinder, expansion tank in loft etc.
There's a problem at the moment whereby when the domestic hot water is on by itself, everything is fine.
However, when he switches on the heating, a load of water shoots up the vent and into the expansion tank, then starts over flowing continually.
Anyone got any ideas?
Any help would be much appreciated.
Probably due to a blockage somewhere, need more info on the system - motor valves etc.
HW is possibly gravity looped and CH pumped leading to pump over due to incorrect plumbing.
Could be blockage as well as mentioned already.
I doubt it's been incorrectly plumbed, as it's been an installation that's been there for years, and this problem has only just started happening.
My initial thought was a blockage somewhere as well. Mainly as I don't think he's ever had any inhibitor in the system ever.
Do you think if we drain some water out of the rads, then put in a couple of tubs of Fernox, it will dissolve any blockage?
As always, any help would be gratefully received.
Graham
Will Fernox dissolve it, or is the only way of getting rid of it is to cut out and replace the blocked part of the pipe?
