OMG
I mix it up, start to apply it, taking reasonable care to work it into the cracks (20mm deep - 20mm wide) I'm trying to fill. By the time I've worked my way through half the mixture (of which there is very little but about 5 minutes worth of application) it's already setting.
It's setting faster than I can apply it and if I make less I'll be mixing every 5 minutes.....
Should I be using a different sort of plaster althougher, one that doesn't set in 5 - 10 minutes? or am I just a clueless numpty?
cheers
Eggers
cheers
Eggers
