Don't need one mate.
Mains cold water, hose pipe, two drain cocks.
Cheap as chips. Powerflushing is grossly overrated.
It is overrated, but with your suggestion the water simply passes through the open paths of the system without collecting any sludge. All it shifts is what's already suspended in the water. Only chemical breakdown or physical shaking will disturb the stubborn stuff.
Scoff you may, but it works extremely well. Back to school for you TonyI can laugh at that too!
Putting a magnet on the OUTSIDE of a steel rad will mean that virtually all the magnetic flux will pass along the radiator steel and not go through it as you hoped !
No need to - I bypass the meter anywaythose magnets must be real powerfulHave you ever put them near your `leccy meter
