- Joined
- 11 Dec 2007
- Messages
- 423
- Reaction score
- 6
- Country
Looking to see if someone can link me to some suitable filler for this. As you can probably tell from the username, I'm a DIY Donkey.
Without getting in to the embarassing details, we now have various holes in walls as a result of a drill bit. Think it was 6 or 7mm.
So, 2 in the upper section of a window recess in an extension that was built around the year 2000 (I say that because of the difference in wall between this and the next bit)
And about 3 or 4, one of which is a little large, in to a horsehair plastered wall (1930s house).
As well as what kind of plaster, would it need to be gun application? I'm asking as if it's by those spatula-like things (told you DIY Donkey) then that only covers the surface of the hole - where the hole was drilled for a rawl plug, so there'd be a good gap behind the surface fill?
