This is wordy, but I want to give an accurate picture of my problem.
My flat = 1960s conversion in Victorian house. Tiny bathroom being refurbished with Council grant, a shambles so far and I am severely restricted as to choices.
Immediately on top of the floorboards were (approx) half-inch thick insulating tiles, they looked rather like papier mache made from cardboard instead of paper. These have been removed but the remains are visible where they've been cut off in the doorway, so you can see they were a substantial thickness.
The plumbers partially covered the floor with tacked-down sheets of very thin hardboard on top of the (gappy) floorboards (through which can been seen the downstairs neighbours' ceiling lights - the plumbers caused a leak I had to clean dirty water from their bathroom floor and toilet seat cover).
The contractor plans to complete the coverage of the floorboards with a bit more thin hardboard, then put a layer of screed and then the Polysafe flooring on top.
Flooring = http://www.polyflor.com/JH/SampleBook.nsf/PHP?OpenForm&ProdCode=FXSC149&Shade=4370&
Is there a modern equivalent to the cardboard insulation tiles that could go under this flooring? I am very anxious indeed to prevent noise nuisance to neighbours as well as to have comfortable flooring underfoot.
clemenzina
clemenzina
