I've a 'space' problem fitting a trap to a 2 bowl sink.
I want to run the waste into a stack pipe situated in my garage, the floor of which is some 15 inches higher than the kitchen floor. As a result, I only have a gap of some 6 inches from the underside of the sink waste/overflow fitting to the base of the 7 foot pipe run at the sink end if I work to a 1-in-80 drop.
I had planned to fit Wirquin's espace extra flat bottle trap which accommodates an also necessary appliance plug as well as both bowls, but have now discovered regulations require the trap to be 75mm when fed into the soil stack.
Does anyone know of a piece of kit or another solution to my problem?
