A builder built me a low garden wall (600mm max) 4 years ago. This was backfilled with earth to within 20-50 mm of the top. The top was normal bricks on their edge. After a couple of years the tops of 50% of them were badly spalled by frost with 5mm or more flaked off. I tried a silicone waterproofer but did not make any noticeable difference, possibly because the main water ingress is from the earth and not from rain.
I then in 2009 capped them with mortar and narrow B&Q sandstone paving slabs 50mm thick and wide enough to well overhang the wall. After the hard 09/10 winter 50% of these slabs have come loose and I see that there is further spalling of the bricks underneath, both of bricks that were previously and not previously spalled.
I intended to use a lime mortar as I read it’s more frost resistant, but think I made a mistake and only used it for part of the wall. Maybe the 50% that failed is the bit that used just sand cement mortar. A clue is that the mortar did not stick to the slabs at all on these loose ones, so maybe the problem was that mainly that I got the mortar all wrong. It was premixed Hanson stuff.
Some of the wall has small quarry tiles on the top and this failed in the same way although on these the tile adhesive was stuck to the tiles still. None of the faces have spalled below the top row.
Any ideas what to do next? I am thinking of applying a stabiliser solution (like dilute varnish) to penetrate the top of wall. Then apply a tanking type water based bitumen emulsion. Then blinding this with sand and lime mortar the slabs back again. The idea is to provide a little bit of flexibility between the mortar and the wall to stop minor spalling loosening the paving and seal it well against water penetrating at the mortar. But if the predominant problem is water penetration via the earth then I am not sure my solution will really help as it does not stop water seeping through the wall to the brick/ bitumen interface and spalling the brick there. Although the paving makes it harder for the temperature at that interface to get below freezing.
I suspect too that the builder’s choice of bricks was not great, although he used the same for a garage wall and that is fine.
A desperate solution might be to take off the top row and use a proper frost proof brick instead for that row, but it’s a lot of work and can I be sure that it still won’t spall along the top of the second row as my paving slabs don’t seem to protect that interface well?
