I have never used an SPD … so new to me.
I know if you install an external EV charger, you should feed via an SPD.
Question is would it be valid to look at installing an SPD to protect whole house … I.e. on the incoming tails.
My limited understanding is that a Type 1 SPD could do this ….. thinking that having an SPD and double pole switch has benefits of being able to safely isolate house from supply.
Twice in last month had Electricians undertaking work, and they broke seal and pulled DNO fuse to provide required isolation. (One fitting Smart meter, other installing Solar EV battery solution)
Fine, understand why they did it …. but I then have to contact National Grid to get fuse resealed.
They are coming back today for 2nd time … and put in writing. “the electricians don’t have the authority to break the seal or remove the fuse as that is NGED equipment. ”
At least if I had the SPD it would allow the isolation.
