RF Lighting said:I reckon my speakers might melt bell wire![]()
1970's Head Banger.
Amp turned up to 11.
Speakers the size of freezers.
bernardgreen said:Wow...... I know ampliers can melt wire but the energy from a speaker melting wire. No way.....
( if you speak into a speaker it may act like a moving coil microphone and produce a few milliwatts of electricity on its connections. )
Sam Gangee said:Out of interest, how many Watts are the speakers rated at and how many Ohms? Answer in Watts RMS, please; not Watts "Peak Music Power" (which is meaningless). My speakers are rated at 10W RMS so bell wire is more than adequate. I calculated that the total resistance of 3m (doubled of course) is 0.25 Ohms. Not very significant for an 8 Ohm speaker.
In the end, the answer - if you've already got some bell wire - is to try it. As I mentioned previously, it won't do any harm. (It hasn't done my speakers or amp any harm. It hasn't melted the wire or insulation).
Sam Gangee said:If you can afford that sort of stuff, try here:
http://www.glodark.co.uk/audio/unique.htm[/QUOTE]
loved the 6.3 volt ac battery that will explode if used above freezing!!!!
