Speedfit and WRAS confusion
12 Apr 2026
I'm confused about whether this fitting is safe for potable water or not:
https://www.johnguest.com/gb/en/pro...valves/stop-valves-and-shut-valves/drain-cock
Now yes, I can see that on that very page it states "Suitable for central heating systems only" and it does not mention WRAS approval.
However, two points... The first is that many sellers, including big name ones like Toolstation say the product is WRAS approved...
Toolststion: "BS EN 7291 parts 1, 2, 3 and S, WRAS approved"
BES: "Approved by WRAS"
Moreover, JG themselves state that
"Speedfit products are... approved by
the Water Regulations Advisory Scheme"
Also here, they answer the question about "WRAS approval" with "Yes, Speedfit fittings and pipe comply with the Water Regulations Advisory Scheme (WRAS)"
So which is it?? WRAS approved or not? And if it is WRAS approved then why are JG advising to only use it in central heating systems?
Might have to get the required info from the horse’s mouth themselves?! Not only does the website say “CH only” it doesn’t specifically state WRAS accredited whereas it does for other products. Toolstation’s ad also says CH only - that TS says WRAS approved wouldn’t, in my mind, override JG not mentioning the same
Maybe use a different manufacturer, or better still, use compression or solder it - problem solved. Not all WRAS approved stuff can be just installed, not a lot of people know they come with IRN’s as well.
Notice this some time ago we use the tectite version.
The tectite data sheet clearly states for potable water central heating and non potable water.
For use with push fit and press fittings.
We use them with press fittings as you need the longer stem.
Look at JG's data sheet for the fitting rather than the web page - web pages can be wrong, data sheet normally aren't - It is classed as being suitable for Hot/Cold and CH systems
Guess the question is why worry. A drain off, by it's very purpose, won't be carrying water that is then to be used for say drinking as it's being drained down, usually into a drain/waste, so whether it's for potable water/WRAS wouldn't really matter. That being said if it's been made to comply with BS EN 7291 parts 1, 2, 3 and S then that standard's been approved by WRAS.
