speedfit fittings
17 Feb 2008
Berkshire
Is it ok to connect to excisting copper pipe below floorboards using speedfittings and the plastic pipe that comes on 50M rolls?
well is not been around as long as copper, so dont think anyone could answer that with accuracy. seems to be ok to me. if only had to sort out bad joints in speed fit, not proplems with pipes.
if your worried then do it copper
my plumber is useing it, and i thought it a bit DIY
It gives that impression!
Ive only once had to replace a section of burst plastic pipe. It was on cold main and about 10 years old. Personally i think it may have been damaged during installation as it was an odd place for it to go.
where do i get a shock arresters and what type should i get.
I also notice that speedfit barrier pipe can be bent round corners with the use of a plastic angled attachement, similar to those used on back of washing machine waste pipe. Are these available for Blue MDPE mains water pipes?
i mate of mine has 2 properties in hull . he rents them out. they are obviuosly in a bad area. when he bought the house the central heating had been ripped out already by the locals"
he put some tenants in. they moved out. a week later the copper pipework was gone. he had refitted and it was stolen yet again house empty and my mate lives in leicester.)
He finally went with plastic and that not been knicked yet, and probably wont be.
mind you its nearly impossible to get nice parallel drops etc as the pipe sags/bends with the heat !!
