Hi
I need to add a radiator and move one other in my house. In the past I have used copper pipe, but this time it will be much easier to use plastic barrier pipe.
I will need to run the new speedfit pipes under the floor. I will drill a hole in the joists and feed the pipe through.
Where the plastic pipes run through the holes in the joists, do I need to wrap the pipes in any thing to stop chafing or noise during expansion? Is it best if the holes are a loose or tight fit around the pipes? Any other advice?
Many thanks
Many thanks
