I only use copper. Never touch plastic.
Went to a job where one of speedfit supplying to electric blow apart by ice in freezing weather,
You lost me there dude.
Speedfit - You say it's the cheapest, but cheapest isn't always the best. As for the PEX pipe it's almost impossible to use from the coil, therefore you end up using straight lengths and more fittings making the "Cheaper" system more expensive.
Polyplumb - Is the old technology ("O" ring first Grab Ring Second) you are more likely to get an installer error because the pipe has not been fully inserted) Fittings can't be re-used without replacing the grab ring.
[/quote]Check out Polymax fittings too.... Think Hep2o may have a copyright case!!!!
Never found speedfit to be a very good conductor...![]()
Yep all we work for (except Shepards) want polyplumb in walls and polyfit for the rest?
Poly Max is the cheapest followed by fit then the grey Plumb. Got a big site coming off with Polypipe spec. Was thinking of polymax BUT what is putting me off was I have never seen it and the only stockest I could find was Wilkos!!!!!
