Hi all, I wonder if you can offer some advice, I have a new build property 2008, and that cheap plastic piping for hot water and central heating pipes. I have three floors and the boiler is a modern gas driven unit that also stores water, there is an electric immersion but that's always switched off at a main point. The problem arising is on the ground floor toilet whee I am gettig short spells of hot water coking out of the cold tap! Now I checked but it's the only sink in the house that has separate cold and hot feeds so two taps.
I checked the boiler this time I noticed it and all is functioning well, the pressure was good and it wasn't fired up as the water must have been up to temp... Any advice ?[/list]
