Spilt drink, tripped fuze
3 Sep 2015
Hello everyone,
I spilt a drink from a table down a wall and into a socket. This tripped an rcd, so I switched off all other fuzes on this rcd, switched back on again until I found the culprit fuze.
I have taken the face plate off, hoping the socket will dry overnight. If this still trips in the morning what else can I do?
Leave it longer, or buy a replacement. Is the drink likely to leave a sticky residue?
BTW - it's 'fuse', not 'fuze' (didn't that get flagged as an error?
), and if you can switch them off it's neither - they are miniature circuit breakers, MCBs.
I did wonder that when I posted. There is a record label called fuze, that's my confusion after a stressful couple of hours.
Was a glass of red wine, which has been cleaned up as good as possible from the socket (and cream carpet, sofa and wall :( )
Also, to add to the complications, it seems the downstairs sockets minus kitchen and just one of the three bedrooms upstairs are on the same ring. Which seems odd but there you go.
if you've taken the faceplate off and disconnected it from the wires, wash it in warm water with half a drop of WUL. Then rinse it in clean water, shake the loose water out of it, and leave it face down to dry overnight.
this will remove the traces which may be corrosive or sticky.
Washing sockets and putting them in the oven to dry?????????
If it still trips buy a new one!!
Not sure about oven, but anyway who would want an odd socket, we don't even know if those sockets are still available. So definitely better for a diyer iy try to clean the existing plastic and metal before wasting it
WUL? What is it?
Seems to work fine now, which is good.
Red wine stain another matter mind. :/
Clearly yet another reason to favour beer!
For most of last week, even with automatic vents and louvres, my greenhouse was well above 40°C until I opened the doors, so that would have worked as well as the 40° oven that BAS suggested :-)
Kind Regards, John
