spluttering hot water bath,
13 Dec 2012
Newcastle upon Tyne
Hi guys i have a condenser boiler ,the prob i have is the hot tap on the bath will splutter then stop or run slow or even just trickle ,but sometimes its ok ,the basin and down stairs taps ok,i called B/gas the engineer said it was not the boiler ,and have to call a plumber,i had a new bath fitted last year wondering if it could be a faulty tap, bath has two taps not mixers, thanks
If you grip the tap (the bit you turn) and pull it upward when the water is flowing - does the flow improve? It may be the little circlip inside that's broken.
hi Joe i have put in a new tap insert and touch wood seems to have cured the fault, tried tap before replacing fault was still there after replacing was fine thanks,
