Hi everybody,
I've recently bought a VW LT van and have brake problems. The pedal is very spongy. It will firm up a bit with pumping, but will slowly creep to the floor when pressed. Thought this may be the master cylinder, but I've changed that and the problem is still there. There are no obvious leaks in the system and I've also used a gunson eezibleed kit on it and there appears to be no air in the system. Anybody got any ideas?, could it be one of the wheel cylinders passing, but would the brakes not still be ok if one was a bit dodgy? could I clamp off the hoses before the wheel cylinder to check if that is a problem?
Any help much appreciated.
Iain.
Iain.
