Spur - best way to connect to supply socket
12 Jan 2009
Cardiff
I'm trying to add a spur. I have mounted and wired the new socket and run the cable to the supply socket. I tried to connect the three wires (2 from the loop and 1 for the spur) into the supply socket and it wasn't happening! The wires won't stay in the screw holders. Is there a better way to do this? (I was thinking maybe a junction box with the three cables going in one side and a single line out of the other side that then powers the supply socket??)
Hope that makes sense, many thanks
No reason why three 2.5mm conductors should not fit into one terminal hole and be retained. Remove the grub screw from the terminal (don't lose it), make sure the cables are stripped long enough so that they hit the back of the hole (but there is still sufficient insulation where it comes past the terminal). Insert all three conductors, replace and tighten the grub screw.
I have done this before successfully but every time i had L, N and E all hooked up, one would pop out when I tried to mount it back on the wall - I thought if they do that it would also be a lot safer to use a single wire into the socket?
You can take a spur from the ring by way of a junction box.
Not being able to terminate three conductors in the back of a socket is usually that they are not stripped long enough and/or the existing two are buckled from the previous termination. Freshly strip them, and try again
ok thanks for the advice - i'll try re stripping them (if there's enough cable) and if not fit a junction box
One tip, is whatever you do don't try and twist the wires together, it will increase the overall thickness, and then it definitely won't fit in the hole...
