Ok. It's just to make sure you don't already have too big a shower for the MCB.I will check and confirm but I know it has the thick twin and earth going into this switch and then from here to the shower. I will check the rating tomorrow and get back to you.
Can i also check that the cable from the shower switch to the FCU needs to be the same thickness as the cable going into the shower switch?
The cable from the FCU to the light can then be 1.5mm t&e?
Yes, that is correct.
