Can anyone suggest a product that is safe to use to lubricate the fridge door please. I was going to use WD40 but because its quite smelly I thought it might contaminate the contents of the fridge.
I would think that its a steel pin in a nylon bush/hole, it shouldnt squeak, see if its possible to clean it. If you cant a bit of vaseline will be ok, but it will collect dust/dirt.
if you decide to apply WD40 or similar, squirt a bit in a jar and apply it with a fine (artists) paintbrush. then you won't risk squirting it into your fridge.
