Got an end terrace that had chimneys removed at some point in history, then at a later time but still some years ago, the stacks were removed but the gallows and most of the gathered flue was left in the loft space. The top 4 or 5 course on the remaining flue are really unstable, the mortar has completely failed and the bricks can just be lifted off without even a tap.
If it's removed it will leave about 2mtr wide central section of gable end wall from cieling joist level to rige as a single skin, what kind of support will that need - will the centre wall that seperated the two middle flues be sufficient support for this?
If it matters the roof type is purlin with ceiling joists resting on internal spine wall, no ties or struts.
